does the complete se 6 speed for a softail come with the side cover for your standard clutch setup or no side cover at all
thanks paul
You're an evildoer.
From what I gather is, if you get the gear set, you have to buy the side plate and modify the case a little (i.e. Drill a new hole for a bolt or some stuff).
If you get the whole thing, its a whole transmission.
Hellbound Train
thanks paul
You have to order the side plate extra depending on actuator type:
Cable actuated 38752-04
Hydraulic actuated 38753-04A
