Anyone know the rod length for the S&S 106" with the 4.5" stroke flywheel?
If you are looking to buy that kit , I would do a search first. The piston used in that kit is a extremely short set up with the wrist pin that is almost into the second ring. You install the pin & clips into the piston, then a support rail(supports the oil scraper ) then the oil rings into the piston. These kits had piston rocking issues and oil use issues.
