1 - 14 of 14 Posts
· Registered
I installed Night Train handlebar and risers on my FXST. The reach was just a little too much for me. So , I bought a set of Custom Chrome 6 1/2" risers, with a 1" pullback. The problem came when I went to install the top clamp. The stock bolts were too long, as the thread holes in the new risers, were not drilled all the way through. So I neede shorter bolts. So I go to Lowes, and search for 5/16" x 18 x 1" bolts. The only thing I found, were the black bolts. I was searching for stainless, but they had none. Will I get rusty nuts (bolts)?
Don
· Registered
Rust.... Dealer for chrome... specialty fastener house for stainless. Some dealers will special order bolts.
You could also powder coat the bolts you have or spray them with a good Rustoleum black (least protective option, but better than what you have).
· Goooood morning, Vietnam!
A company called "filmloop.com" is putting cookies on your computer by calling up this thread. I think it is coming from captainlee's sig line. Just an FYI in case you don't want unknown cookies on your PC.
:nunu:
· Incredible
Thealien said:
Risers can put a lot of strain on those bolts. Personally I would not go with chrome (chrome bolts tend to become brittle, chrome can peel making it difficult to remove). I use grade 8 stainless bolts for everything I can. I buy them from www.alloyboltz.com great people to do business with.
Cool link for stainless bolts. I am replacing all the bolts on my bike with stainless instead of chrome. There is one company I found for 120 that includes all bolts to replace factory with stainless. I like not needing to worry about rust or wrinkling the chrome tightening a bolt down and then it just rust also.
· semi-retired
strong & rust free
I've used diamond engineerig's s/s nut,bolts and washers for the lst 5 years-good sh*t !
· Forgetter of Things
JohnC said:
If you have an Ace Hardware nearby, they sell a huge selection of stainless steel bolts. They also sell a limited selection of chrome-plated bolts as well.
the Ace Hdw. near me has the same...and the price is great. the chrome plated stainless(buttonhead) that i bought were a little higher priced...
· Incredible
You definitely can't go wrong with stainless bolts or screws for that matter. When I was outside late fall working on my deck I used stainless screws. Theoretically when I need to replace some boards in the future I should be able to back them out and screw down the new board with the same screw.
1 - 14 of 14 Posts
