Just wondering about my carb, I Re-jetted my C.V. carb & now the rear cylinder is running rich, My bike is a 02 1200 , I did'nt remove the intake so I don't think it's a leak there. Any help?
Later Larry
If one cylinder is running much richer then the other then you have a vacuum leak at the one that runs lean, unless you have a ignition or mechanical problem on the rich one. Simple.
Maybe something as simple as the accelerator nozzle aimed wrong can make you THINK one cylinder runs rich.
I agree with Hippo. My XLH has the intake off right now because of the seals leaking. The front was running way lean. Got to make sure you use enough WD-40 around them seals to check for leaks. It works real good...
