1 - 10 of 10 Posts
I've always run 40 pounds front and ~42 rear in my wire rimmed RKC, basically because I've never seen what they "should" be set to. Anyone know what the pressure should be? (solo riding).
I guess the second part of the question is should a tubed tire be at the same pressure as the tubless tire has listed on it?
2001 HD Service Manual for Touring models states the following for stock Dunlop tires.
Front Tire
36 psi for solo and 2 up riding
Rear Tire
36 psi for solo riding
40 psi for 2 up riding
This info should also be found in the Owners Manual for your bike.
Knower of Stuff
Max tire pressure for a D402 is 40psi per the tire sidewall. Running 42 exceeds the tire specifications.
road_kings posted numbers are correct and should be followed.
Nice to ride again :-)
Always follow tire manufactures listed PSI based on load. I have Metzlers and I use those numbers, others Avons.
I used the recommended tire pressure on the stock rear tire and got 10,000 miles out of it and could have went more.
LAF, you got 10K out of Metzlers? I ask because I new tires and everyone here says Metzlers beat the Dunlops hands down but the Metzlers don't get as much mileage. I am pleased with the Dunlops and wouldn't bother me at all to go with OEM's, But are they that much better (as far as rideability and handling)?
I know this has been beat to death, but as I said I saw your post and was curious. Thanks, Joe
No, out of my stock Dunlop rear.
I am sure I should be able to do that out of the Metzler's also.
I guess that all depends on how you ride. I push it sometimes so I like a better traction tire, I like the tread pattern also. I ran Avon's also and loved them.
If you are just cruising and don't ride to aggressive then OEM Dunlops will serve you well.
Premium octane member
05 Road Glide 95 in the Bag
Built by LAF and Dynathearpy 1/22-23/2005
NRHS Stage II Heads/85cc /10.5:1/CP Pistons/Woods TW6HG Cams/S&S Gears/S&SRollerRockers/Crane Tappets/Smith Brothers 3/8" Molly Push Rods/Vance & Hines True Duals-Ovals/Baisely Spring/DTT TCFI/ SE Clutch Spring/Super Premium Oil Cooler/Doherty Power Pacc/True Track/Velva Ride Mounts .............LAF'S sig
man i see your sig all the time and i never would have guessed you getting 10K out of a rear tire..My bike is still stock for now and i find that the rear tire gets happier(read:smokier)than the front sometimes.......nice ride you got though
I had good results running Avon tires for a dozen years. The Dunlops the bike had when I bought it were toast at 12000 mi. Im currently on my first set of Metzeler ME880s and after 5000mi I like them a lot. My local bike shop has a Snap On computer balancer for bike tires, and I recommend having it done. I found a more uniform wear pattern with no cupping, and managed to get an extra year out of that pair compared to the set before them.
1 - 10 of 10 Posts
