Rinehart True Dual Install sheet...Project complete
Need some help. I would like to pull off the right side Rinehart from my Street Glide to do some mods to the bike. Started dorking with it tonight, and have hit a brick wall. Can't get it to budge. Does anyone have the installation sheet from BUB, so I can do a little reverse engineering? Or hint to as to get things loose?? Thanks for any help.
Well, it's only attached at three places. The "hanger" at the rear, with the two bolts/nuts... midway along the pipe there's a clamp holding it to the transmission door, and the usual two exhaust studs at the head.
You probably just overlooked that midway clamp. You'll need to remove the heat shield to take it loose and get the pipe off.
Thanks for the advise. Once I had the heat shield off...it all became very clear. I finished my weekend projects. Put on a little chrome...
