Brian,
As you know, I intentionally undercammed my engine for the riding I do and I might be considering the 647 Red Shift. I always thought that cam might be a better cam for big CI engines as opposed to the 657, and it appears you proved it. Anyway, after visiting with you this morning, I hope you are able to post the numbers for your reworked HD heads with the 647 cam so we can see the 30 hp or so the STD reworked heads add to the engine. I am interested in the torque curve differences between both sets of heads with that cam, too. You may recall that I run the DTT WEGO II efi with the 57mm Kuryakyn (6.1 gram p/s Marren injectors). My spring pack should hold the 647 RedShift (AV&V big base at 185 lbs seat pressure, flurocoated) and my recollection is that the piston to valve clearance can handle .700 lift (I will verify this as well as compression which ought to be 10.2 to 1 ratio at present. I could trim the cylinder bottoms for a positive deck height to increase the compression ratio if necessary for the 647 Red Shift cam while leaving squish at .030" cometic). I guess you see where I might be headed with my bagger. KT set up the valve train geometry and I have his spec/assembly sheet. I have a set of Stock black take off heads (pre 05) on the shelf, so............. .
Here's hoping you have a prosperous 2006.
STB/Counselor ;-)
