The "grommet" or whatever it's called, is a piece of rubber with a brass nut in it that expands when you screw the windshield screw into it. I thought about epoxy but it has to be in just the right place so the screw will go in it, and the hole is so dang big I'm afraid I'll get it out of line. I've tried new ones and they just pop out as soon as that rubber mounted motor throws a little vibe. By the way, it's only one hole I'm having a problem with. But it's still a PITA to change windshields with the mounting system and weatherstripping. Guess I could take it to the dealer since it's still wrtd and let them bother with it, but I'ld rather do it myself.MegaGlide said:When you say "grommet" are you talking about the brass insert, or something else? If it's the insert, epoxy.
I googled this up.stanc said:Hey Dwarthog, if you find some of those larger sizes I'ld appreciate it if you'ld let me know. Thanks.
