Sounds like it's too rich. Do you know how to correct that?
found what works on mine and dont foul plus & starts up quick and stays ruinning when cold warm ups . Set compression release buttons pull out choke get it 2 twists on the throttle reach down and crank the idle cable screw anout a turn . Crank over the motor when it starts let it run about 1 min put choke in now its running on fast idle let it warm up on that now reach down and adjust the idle cable back to 1000 rpm its ready to ride this sounds like a pain but so is constant plug foulingi know this is an old ass thread but i still would like to answer, since i have a revtech 110, i switched from an s and s to a mikuni carburetor and it runs like a beast. My husband also switched carbs on his 98 fatboy and hasnt had any problems anymore, he was fouling out plugs within 2-3 blocks, and it was the damn s and s carb.
Get a makuni carb and you will immediately know you have fixed your problem :clap:
