anybody know what the readings should be for a full tank and empty?
or if you know what sensor type it is, sun, warner , ford , GM the dealer does not seem to know
If you have a service manual it will tell you the resistance and how to ck it. I had to do this on my 2001 heritage. You have to remove float system from tank to do this. Use a good digital meter and move the float up and down checking the readings as you go. Good luck.
Fuel level sender test 2002 models
Info taken from 2002 Electical Diagnostic Manual for Touring Models.
pg. 2.1
Full fuel tank resistance 7-14 ohms on FLHT and FLTR models.
Full fuel tank resistance 27-40 ohms on FLHR
Empty fuel tank resistance 74-95 ohms on FLHT and FLTR models.
Empty fuel tank resistance 240-260 ohms on FLHR models.
thanks it does have it in the manual turns out it's a ford sensor for ultra's ,
shocked!
I'm sure I'll get flamed for this but, knowing I got Ford parts in my
FLHT's gas tank feels like a slap in the face.
