If you are running anything 10:5:1 and lower, I would suggest the Harley Davidson cast flat top pistons. They are cheap, solid, and reliable. I would start looking at those forged pistons if you are going to run over 10.5, NOS, or a turbo kit. If you are going that high, then sure...wiseco, or the others. Wiseco has the time in the business to know what they are doing. Whatever you do/get...be sure to break them in properly. That's my brand suggestion, others I am sure to follow. Harley also makes a slightly domed cast piston if that is how you want to bump up compression, but not as far as 10.5:1. I am on crappy internet here...so I can't look up the whole SE book and get the exact specs.
Another option would be to get the flat tops...and have the heads cced and milled. That will cost less that $100 and can get you to the exact compression ratio you want. You could also have them ported while they are away....saving the money on the cylinders/pistons by going with the HD flat tops and the machined cyliders would make this more possible, but again...that is if it is in budget.
Note, increasing your bore has already increased your compression. It would be a good idea to cc the heads and see where you are at before throwing in random domed piston kits and the likes. You might already be over 9.5:1 if you bore to 103. Its hard to tell without doing the math. There's a good bit to think about when you are increasing compression. Don't think it through enough and you could find yourself in a rough spot. Just a warning, not a deterrence to building your bike.
I still say HD flat tops, cam (S&S, andrews, HD), find your compression ratio, and refuel it right.
Steel
Edit: Then there you go. The pistons are different in length so one doesn't meet the crank. Must say I don't have a bunch of S&S piston kits laying around to look at so I haven't had the opportunity to compare the pistons. This goes the same for 95s and 103s though, for the same reason. Still should hold valid the comment about the quality of the parts...unless S&S jacked up their larger stroke pistons and they are eating cylinders. So what if dyna put 4.375 cranks in his 02? He would probably just have to swap to the other piston because of the skirt. Then he would have the 106 kit. Or no?
