Thinkin' of removin' the rear shifter arm and peg or maybe just the peg on my '02 Ultra. This would give a lot more room to move your boot around on the floorboard.
Anyone done this? Did you remove just the rear peg and leave the arm? Did you remove the rear arm too and if so, what did you use to take up the space where the arm is attached with the front shifter arm?
Is this something that an MC (mechanically challenged) person can do?
I also bought a nice pair of Harley black leather lace up boots. Problem is, the toe and sole is so thick it doesn't quite fit under the front shifter peg. I'm guessin' the front shifter arm can be shifted around and remounted on a different spline to give more room?
Thanks ...
Thanks ...
