1 - 9 of 9 Posts
I'm installing dual exhaust on a deluxe on the left side of swing arm there are two plastic plugs that cover holes for mounting a bracket for dual exhaust I have tried pulling them out but wont come out does anyone know if these screw out.
These plugs are hard to get out. I ran into the same thing on my Heritage, you just have to work at getting the things out.
Oh yeah, they are not really threaded. They just have a few rings, that hold on really well.
alperin1
Thinking the threads in the frame would help I used a small pick or screwdriver to pry up opposite sides of the cap and grabbed it with needle nose plyers and turned it out like a screw. This worked pretty well.
Be careful with the length of the bolt you put in there.
I just put pipes on my fatboy. I drilled through the plastic caps to weaken the plug. Then I grabbed a hold with needle nose pliers and yanked and twisted. Came right out.
Use a drill bit smaller than the hole that the plug sits in. You don't want to damage the threads. Go in straight, and be careful!
1 - 9 of 9 Posts
