You can do it with the FM and if you get stuck the forum is here.
Springer's analogy is pretty much it, and it is that simple.
Just observe the patterns and order associated with the top rocker bolts, breather bolts, rocker support plate bolts in both taking off and going on, and you got it made.
The worst part on my bike is the gas tank, even with the light on I got about 1/2 gallon and draining and working with the crossover tube is a PITA. I solved it with a braided crossover with a quick connect to the tune of 100 bucks. It was my nemesis though, I hate gas all over the place, so worth it to me.
You might want to look into the intake bolts, I have the snap on tool, but before that I used a allen wrench I cut the leg down on.
