The best thing is to get a service manual and it will tell you how to do it.minivan said:I am interested also.. Specifically about lifting up the fuel tank to unplug the headlight to install mine..
Do I need to take off the seat, and take off the rear tank bolt?? Or can I just take out the front bolt and lift the tank up to get at the headlight wire??
I thought the same thing on my deluxe ,after reading the manual , lifting the tank was pretty simple.dwelch7 said:I pulled mine apart (to black out the front end), but I didn't disconnect the wiring harness - I pulled the pins out of the headlight plug, cut the two ground wires, and slit the rubber boot at the headlight bucket. I put a male/female plug on the ends of the ground wires (with a plastic boot), and sliconed and taped the plug back on the wires. Seemed like a lot less work than lifting the tank, and now I can just unplug it next time
Dave
Damn, you sound like me... Its on order, just thought I could get some early help while its so cold outside.....mori55 said:The best thing is to get a service manual and it will tell you how to do it.
