1 - 2 of 2 Posts
First of all I whant to enshure You, have not smocked nothing bad. But, just for speacking, if in future would go for a 6 speed tranny with sprocket and belt on the right side od the Dyna, would be possible intsalling a stator in the sprocket empty place, after the clutch?. Shurely that will need some modification on the assle coming out from tranny but there stator should be air cooled, and not.... oil coocked
Hellbound Train
I would think this could be quite expensive and unnecessary as the heat isn't enough to do any damage to the stator (it's only copper and steel) so I don't see a benefit. And what would you do for power when the clutch is dis-engaged? By the way, you woud be placing the rotor on the shaft and you would need a close tollerance stator support and cover.
1 - 2 of 2 Posts
