1 - 19 of 19 Posts
I 've heard you can get the ramps only for the reduced effort clutch kit that is stock on the 06 Dyna. I don't want to replace the spring in my SE kit.
Anybody know the part number for the Ramp only?
ramps
Harris said:
The outer ramp is 25605-00. The inner ramp is 25604-00. The diaphragm spring is 37882-06.
Harris
Do you know if that includes the ball bearings? I guess that I could use my old ones.
greg
Discussion Starter · #7 ·
MANY thanks !
Newer Version
I believe the PN's that Harris referenced are the old 21 degree ramps. The new ('06) version with the 18* ramps have an "A" suffix.
25604-00A-inner
25605-00A-outer
See Service Parts list in the attachment.
G
25604-00A-inner
25605-00A-outer
Good catch. In the directions for the reduced effort kit, it did not add the "A" suffix, and I didn't look at the P/N of the stock ones until your post, but they are the same.
I did notice that the ramps have either "18" or "21" cast into them.
Harris
Discussion Starter · #10 ·
thanks for the clarification !!
Discussion Starter · #14 ·
The reduced effort on the new Dyna's is real nice , even back to stock is a plus although I'm getting used to the heavier pull. Hey Mega ..thanks for your insight.. man o man I'm likin the new power
Discussion Starter · #16 ·
I've been playin guitar and bass for 30+ years , plenty of strength in the left.
What about just the ramps? I got the 21 ramps. Got the ramps out right now and was thinking about replacing. I wouldn't think there would be an issue with a 98", since your not change springs r diaphragm??
"What's this do?"
berserker, I put the 18* in my softail; changed nothing else. Works fine. I wanted to do it while I had the exhaust off. However, when I get around to it, I'm going to install the SE spring. I also changed over to Amsoil Super Shift transmission fluid in the primary. I like it. Hooks up nice; shifts well.
Is it any better, less effort, with jsut the 18 ramps?
1 - 19 of 19 Posts
