Throttle/idle cables possibly rubbing:
1. Harley-Davidson Motor Company, Inc. has learned that a
condition affecting safety exists in certain 2004 Dyna
FXDL/I, FXDWG/I, FXD/I, FXDX/I and FXDP model
motorcycles built, from June 11, 2003 through February
2, 2004. The affected motorcycles have a condition
that may allow the throttle cables to contact the
tunnel portion of the fuel tank. In this condition,
the cables could eventually wear through the tank,
causing a fuel leak, thereby presenting the risk of a
fire and possible injury or death to the rider.
Unquote
If the FXDL is like my '95 Wideglide you can remove the front gas tank mount bolt and rotate the tank a few inches. Once it's up a little bit you have a clear view of the routing of the cables and can at least tell if they have rubbed or caused any damage. On my WG the cables run through a standoff bracket that keeps them in place but also keeps them from rubbing the tank. Not sure if the FXDL is the same. I just this morning went with a friend to drop his wife's 2004 FXDL off at the dealer to have the recall performed and documented. However, if it was my bike I would have raised the tank and inspected it myself first. I do recommend against actually removing the tank if need be. Let the dealer do that work if needed...on their dime.
Good luck.
Semper Fi,
Steve....Pensacola
USMC 1972 - 2003
