What the %$#%!%# ?
I am looking purchasing a 04 Standard, but i really dont like the bobtail fender. I want to see if a fatboy fender will bolt right up.
anyone have any pics? :dunno:
The Anti-RUB
I'd like to do the same thing on my '06 FXSTBI. Problem is, the only other 200mm rear fender is on the '06 CVO Fatboys...
should be a bolt on job... I'll let you know how mine goes, if I get around to it.
don't forget the wiring and plate mount! I believe the rear harness is the same, just swap the brown and violet or your rear signals will be bass-ackwards.
I know for sure the struts are interchangeable. :thumbsup:
Direct bolt up I just put one on my FXSTS . I have rewired the rear light I used and LED teardrop and moved the turn signals off the fender.
