Rubber Mount Touring Frame
Because these framed bikes have a 3-point rubber mounting drive line, they can exhibit some minor high-speed wandering conditions naturally. However, if under same-to-same conditions the bike begins acting differently in this area, there are some things to look at.
Additionally, because this frame has a unique reverse-tripple-tree design (which helps the front-end to self-center) the check and adustment process is unique to this type front end. You will notice with any other model, if you lift the front end slightly off the ground, the front end wants to fall to the side. When you do the same to an FLT (Rubber mounted touring) frame the wheel / front end moves to the center.
Steering head bearing preload/adjustment - instead of 'fall-away', as with other models... this model uses a '3-swing' adjustment check. With the front wheel just off the ground far enough not to touch, move the front end all the way to one side and let go. The front end should stop singing on the 3rd swing. The beginning of the 3rd swing I like. you have to check in both directions, and to get the absolute best results, disconnecting the clutch cable sometimes gives the best results.
The procedeure for adjustment of the neck bearing preload is similar to any other model and covered in the appropriate service manual. Understand that when you tighten the top 'lock nut' it will affect (tighten) the adjustment you made with the star-nut. So you have to plan ahead as you adjust the star-nut.
The front (rubber) motor mount deserves a look. There should be daylight between the engine-to-mount plate and the rubber bulge part of the mount. If it's collapsed, replace it... there is a new improved mount introduced just this week after a 27 year run of the previous one. This mount is also used on FXR's.
Vehicle alignment is best done with aluminum channel attahed to the rear tire... the rear-mount special alignment tools, and an inclinometer. Let your knowledgeable wrench do this. Talk to them, see if they're comfortable with this, ask if they have the proper tools.
Tire pressure & tread trueness, shock air pressure, and front-end fork fluid condition and level all play a role in vehicle handling too.
Good luck.
HD
