1 - 8 of 8 Posts
I built my 883 and the old cylinder and plug indicated my rear cylinder was running very rich. Bike had 2500 miles on it 170 jet with [email protected] and vance and hines. Is it normal for the rear to run rich and the front to look normal? Thanks.
Check you intake seals. When everthing is in tune with no air leaks the front & rear should be very close in plug reading.
What do you mean you "built" your 883. Did you cc the heads ect. ?
Thanks, I just put a 1200 10-1 kit on it and bolt in cams, I didn't replace the intake seals though, I just puled both heads off at 1 time. Guess I may have to replace the intake gaskets if it runs rich after the build...Again thanks.
Pull your AC cover and make sure your accelerator pump nozzle is spraying directly at the carbs throat centerline.
Thanks sport i will give that a look as well, and when I find the culprit I will post the it. Thanks guys.
newhere,
did you ever find the culprit? I just rebuilt a twin cam and it's doing the same thing...
rck
My 1200 is doing the same thing. Pretty much a stock bike with the taxes paid. Would like to know if anyone finds the problem. I'm sure the dealer will say it is normal.
same thing on my 03 883 custom...taxes paid,800 miles?MoCo probably knows about it and why,but can always use the phrase"it's normal"
1 - 8 of 8 Posts
