I could probably see that on the front with twin brakes, but on the rear is waaaay out there.... I even saw one were the wheel was on backwards.
All stockIs the stack correct i.e. wheel bearing, spacer, caliper bracket, swing arm.
i don’t use drugs of any kind and that kind of comment is complete bullshit !!!!I could probably see that on the front with twin brakes, but on the rear is waaaay out there.
If you did that, you need to stop smoking when you work on your bike, or smoke a lot more.
It was a hard tail conversion on a sporty, and the guy was using the wheel off of a big twin. The tail kit came with an axle and spacers that were marked left and right. But it assumed the wheel was not turned backwards.I could probably see that on the front with twin brakes, but on the rear is waaaay out there.
Well I found out that I was told wrong about what bearing to install first , and I installed the left one first and that was the problem removed them bought a new set and installed the right one first and that solved the problem. And thanks for your help.What kind and year of bike? Is it a stock wheal, brake, etc? What are you calling a caliper bracket? Posting pictures to show what you are talking about could help. A picture might show what you got wrong.
Well, his comment was in a reply to Therm so I didn't take it as Mr. tootin was speaking of you. Chill out man, it's gonna be OK.i don’t use drugs of any kind and that kind of comment is complete bullshit !!!!
A service manual can help at times.Well I found out that I was told wrong about what bearing to install first , and I installed the left one first and that was the problem removed them bought a new set and installed the right one first and that solved the problem. And thanks for your help.
