stonep said:
When replacing the rear tire on my 02 night train, the technician reversed the direction of the axle bolt. He says it means for my next tire change, there will be no need to remove the muffler toget the tire off, since the bolt now lslides out the other side. Apart fropm cosmetics, is this going to have any effect on the wheel alignment/performance?
This is a safety issue.
The HD Shop Manual says to place the bolt through from the right side. When the bolt is inserted from the right side, any interplay between the wheel, bearings, brake, or rear drive (sprocket) and the axle will tend to TIGHTEN the axle into the nut. With the axle through from the left side any interplay with the wheel (etc) and the axle would tend to LOOSEN the axle into the nut.
Seems like the tech is trying to make his life easier at the risk of your safety. Did the tech secure the nut with a spring key?
It only takes a little more time to do the job correctly.
Incidently, I helped a guy drag his Sportster out of an intersection once. The rear axle nut had come OFF and the axle had work itself out of the swing arm. Fortunately he was slowly moving when the wheel jammed as the axle came loose and he only had a few scrapes and cuts. That axle had been inserted from the left side.
Murphy is alive and well, I'd have the axle correctly installed.
HD tries to cut the maintenance time down on these bikes - time is money for their repair shops. How many new bikes have you seen come from the factory with the axles inserted the wrong way?
