Rb/lsr 1-3/4 Or 2 Inch?
704 Views 4 Replies 3 Participants Last post by  PAULIE61
Which are you using and why? My plan is the 1-3/4, my build is mild, what are the pros and cons of either?
TIA, adx
TIA, adx
The answer is if the motor is under 100 cu. inches you use 1-3/4", over 100" and you use 2". No ifs ands or buts! :D
thanks tote, how do you like yours?
I have the pro pipe now but the one I have I bought used really cheap and although it has served me well, I am pretty sure it was never the correct pipe for my bike as far as fit was concerned. Depending on what source you use, V&H ProPipe for dressers is either 95-99, or 95-up or 99-up. Pretty sure I must have the 95-99, mine is an 01. The the pipe fits too close to the shaft of the rear brake master cylinder, it hits/rubs/vibrates...you get the picture!
Anyone else have this problem?
adx
Love the pipe! beautiful build quality and great sound. Good performance with 102ft-lbs and 95hp with my build and that isn't even fully tuned yet.
Even though it has a 5 lb torque dip at 2650 that we haven't tuned out yet, I really don't care!
:yes: :yes: :yes:
