This is the full list. Tell what you think of the build and what you think it should cost.
9198T 2 Bearing Tort 9198
SS33-5212 1 Heavy duty cam bearing pl
8990A 1 Ball bearing
25533-99A 1 Cam drive gear retention
17045-99c 1 gasket kit cam service
17997-99A 1 Quick install pushrod kit
16101-01 1 Kit gasket TC cyl head
SS93-3030 4 Long head bolts TC88 & 95
SS93-3036 4 SHT head bolt Thk wshr
17052-99B 1 Gasket kit Top end
29440-99C 1 SE A/C kit
32107-01D EFI Race Tuner kit
V17533 1 PRO-Pipe Vance & Hines
65324-83A 2 Exhaust Seal
DS-199538 1 4 Gear set gear drive cams
288167G 1 67G Andrews Cams
DS-223264 1 PRO-Clutch
22851-99A 1 Kit 1550 Piston flat top
34901-94C 1 Gasket Primary Cover
99887-84 1 Chaincase lube
I'm also having my jugs bored out and the rocker boxes clearanced. My stock heads are also getting a full port and polish with valves. The heads are being done by a local guy who has been doing them for as long as i've been alive so the heads will be as good as any head out there.
P.S. Sorry if what I wrote is hard to understand I'm new here and still learning
