Truckman, there are several ways to get more rake on your FXD. Keep in mind that the proper way would be to get a qualified frame man to cut and weld a new neck angle for you. There are other ways but keep in mind that they will change the trail on your bike. The handling will be affected but staying within say 3 degrees want be too terribly bad. The ride would be similar to lowering only the rear of the bike as far as the ride feel goes. Extremes in excess of 3 degrees can be very very dangerous. One way to rake with this in mind would be to use 3 deg. raked neck cups. This would be the least expensive way. Another would be to use raked triple trees or adjustable rake triple trees. Like I say, they are available but not recomended. There are far less stable handling bikes out there than ones using a raked tree but if it were me I wouldn't do it just for looks unless i did it right which is to have it welded.
neck cup kits:
