Based on your knowledge does the radio of a 2003 that has cd work on a 2002, last year for cassette, any mods?
Changing out an '02 head unit for an '03 should be plug and play. You can call HD's vendor of those head units, Radio Sound, at (502) 267-6768 to confirm.
Are the connectors the same?
There is only one electrical connector on a non-Ultra installation and that's a 23-wire Tyco Amp connector. The connectors are the same on '05 and older models and '06 and newer models. They are wired the same except for the vehicle speed wire mentioned in my previous post.
Ultras use a second connector (for rider headset, passenger headset, rear speakers, etc.) and those are different for '05 and older compared to '06 and newer models. The former use a 23 wire connector and the latter a 35 wire connector; both are Tyco Amp connectors.
When I retrofitted the HK head unit on my '04 EG, I compared wiring diagrams for '04 and '06 and newer models, as well as part nos. for those years to confirm that it would be a plug and play installation. With the exception of the vehicle speed wire, it was.
The HK was installed because I wanted a clean CB installation and it replaced a Sony/Biketronics installation that worked great. In fact, but for wanting the clean CB installation, I would not have replaced the Sony/Biketronics combo.
Carl
