Hey Randy, and everybody else...
For Christmas, I got a set of Mikes that range from 0-5" The 0-1 is electronic and so is the 4-5. Rest are digital.
Along with those, I got bore gauges. .7"-1.5" and 2"-6".
Today, I decided to dig these out and start playing with them. I got a handle on how they work and all of that. Set them to be zeroed at the bore dia you wished for.
MY question is how does one check a cylinder bore? Also, what is acceptable for a bore job and what is not.
I walked all over the cylinder and got a difference of 8 tenths.... eg: smallest reading was -.0016 and largest was -.0008. This is a really used cylinder. Has the heat marks, kind of yellowish brown, and can still barely make out the cross hatching. I did NOT measure a piston for my readings, I just winged it on the bore size. 3.937 for a S&S 106 kit that had been bored +10 by S&S on warranty. Bore ranged from 3.9354" to 3.9362"
The heat marks and the skuffing really didn't change the measurements. I am wondering this: if I send cylinders out to be bored and honed, upon their return..... what is an acceptable deviation? Also, does one 'map' the cylinder in specific spots, etc? What 'grid' is used to do this? (NOT THESE CYLINDERS).
trying to learn the PROPER method to do this stuff.
Also, how does one measure a piston? Where is the best spot to check at? Some have coatings, some do not.
Thanks!!!:beer::beer:
