1 - 12 of 12 Posts
· Registered
I have a 98 evo head breather motor. To get rid of drippy air filter, I lengthened the outlet hose and ran under frame to the atmosphere.
I was wondering, since originally the hose vented inside air filtered area to carb, it was adding some air to the air/fuel mixture slightly? If you put your hand over the hose when engine is running, you do feel air pushing (and of course oil mist).
I wonder if it affects maybe the air/fuel mixture at idle or so?
I have noticed a little difference on cool damp morning lately.
It's a mikuni hsr42 out of the box for an evo (stage one style headwork and a ev27 cam)
I'm no official mechanic, I'm interested in others opinions
· Registered
2007 Electraglide Ultra
The engine will pull in what air it needs through the path of least resistance I would not worry about the insignificant amount coming through the breathers as affecting the a/f it’s the oily mist that is affecting it more, that you don’t want going in there.
· Make me use my bullet?
The static pressure in that tiny hose is way less than the suction from the cylinders. It makes no difference at all in AFR. The only difference would be from lack of oil mist.
· Registered
Discussion Starter · #7 ·
This engine has 5k on new James gaskets umbrella valves. When I was fixing a couple broken bolts in cone cover, I threw I the reed breather. The nylon timing breather looked ok, I was just updating stuff preventative. Bottom end had 120k miles. All next top end was done.
Reed seems to blow more oil, but I do tend to ride it harder now
· Registered
2004 FLSTCI, 1993 FXDL
If you lengthen the breather line a bit and make a trap in it you'll minimize the oil spray.
This is a common "bandaid" fix. You're not fixing the problem, you're just covering it up. It's like thinking you've solved the problem of oil dripping onto your driveway by placing a pan under your leaky vehicle. Sure, you've stopped it from making a mess, but it still leaks.
Well, technically, the pan under the vehicle would solve the problem of oil dripping on the driveway. Jus sayin
1 - 12 of 12 Posts
