1 - 8 of 8 Posts
Vibration while riding causes my pucks to loosen and the lids to open. The locks are jammed from road grit and grime so they are not functioning at the moment. I do have one working after using some carb cleaner and Remington gun oil but the other one is too far gone so I ordered a replacement. In the meantime, I have to secure the lids with bungee straps which looks like crap but I don't have to worry about the lids opening going down the highway. I plan to tighten and tweak the wire latch on the pucks as best I can to try and make them stay tight.
My question is if this is a normal issue and if so what is the best fix?
Also, I have looked at replacing the pucks with the flush mount push button latches, are these any better?
Thanks in advance for any replies!
I have the same issues, i bought a cheap flush mount latch off ebay, it was pure junk. I did not install it because i would have had to drill the hole in the top of the lids bigger (permanent modification) and it was cheep plastic junk!!!
I have been thinking about adding some sort of foam to the lid seal in attempt to tighten them up a bit as i think some of the rattle comes from the hinges and tightening the hinges may keep the latches from unlatching.
I have also been thinking about replacing the bags all together. Good condition used harley bags are expensive. The only thing i have read about the cheap ebay after market bags is that cold weather makes them brittle??? but that is not a problem for me as i live in sw Florida. But i belive " ya get what ya pay for" and the hardware will probley rattel open on the cheep ebay bags.
I do not like the looks of those pucks, and anything less than the harley bags will probley be disappointing.
Idk, but i dont think harley hardware is available from hd dealer for the older bags???
But to answer your question, the flush mount latch i got off ebay was of poor quality and had to make the hole in the lid bigger.
I manipulated the puck latches (bent'm with pliers :rolleyes: ) in such a manner that they stay engaged/latched until I turn them to open the bags. Mine never open by themselves now.
Pucks are good (o:
Pucks are good (o:
I like pucking too.
Sent from my moto e5 supra using Tapatalk
Pucks are good (o:
This is what I'm going to try I figure if I tweak the tab maybe the indent on it will grab the wire better. I like pucking around too.
Discussion Starter #6
I've seen some that were cheap and some that were quite a bit more. Then I noticed the cheap ones were described as chrome finished plastic. If I replace them I want metal, like Willyone said a little work with some pliers will probably set me straight. They are almost 15 years old so they have a fair amount of wear. Thanks for the heads up on the plastic Chicom crap.
My pucks stay latched. You have to adjust them over time as it is a friction fit so they tend to wear. Avoid putting lube or grease on them. I know several folks that have the push button latches but I don't know what brand. They also seem to work but they pop open every now and then.
Discussion Starter #8
Tweaked the tabs, repaired one of my locks and replaced the other one. No more pucking problems, bags stay shut on the highway now without the bungee straps.
1 - 8 of 8 Posts
