Nitram_b4 said:
wow, don't think I ever have seen a softail with a front end like that. fill me in
MFSB said:
I love that front end you have. I really would like more info on that if you don't mind.
Accutronix triple trees, Buell XB9r forks/wheel/rotor/caliper/fender, '08 Dyna headlamp, Avon grips, a combination of ARP 12-pt stainless & cap head stainless hardware, Bridgestone 120/70/17 tire. The forks were sent out to Race Tech for their springs, valves, and emulators.
FWIW... The front end is really low at approx. 2" clearance. The Buell forks are really too low for the application, but I plan on modifying them and raising the bike back up another +2". If doing it again I would look into other inverted fork possibilities that are longer... As it sits now getting the bike off the table lift & out of the driveway is difficult. Speed bumps are a no-go...
That said... With the +2" and the rear matching I think the build is Bad A$$!! I love the looks of it all, especially the wheel/rotor combination. Initial thoughts on the handling is completely different from the oem FL setup. The change also net me approx. 58.2 lbs. lighter...
Scrubs said:
Headlight may need to be adjusted though; aim looks a little low.
Yeah... I was using the oem stock FLSTC mount for trial fit at the time, and it's edge didn't clear the lamp for proper aiming. I fixed that last night.
K.
