1 - 12 of 12 Posts
hi all..i am from greece and i have a dyna fxdb 2015 model 103cu....the bike purchase with bigger camshaft ,air filter vans haynes.exhaust vans haynes and strocked up.....when I open full the throttle at 2500 rpm it makes a block up to 3000 and then turns....no matter how hard we tried remap ecu the problem not solved...anything know whats this problem
"hi all..i am from greece and i have a dyna fxdb 2015 model 103cu....the bike purchase with bigger camshaft ,air filter vans haynes.exhaust vans haynes and strocked up.....when I open full the throttle at 2500 rpm it makes a block up to 3000 and then turns....no matter how hard we tried remap ecu the problem not solved...anything know whats this problem"
Which way does it TURN? {on, off, right, left, over, under??}
What happens when the throttle is opened like normal driving?
Maybe the rev limiter is set way down...
Discussion Starter · #7 ·
when open throttle easy not has problem its all good..when open full throttle it makes block up for 500 rpm and after its ok
1 - 12 of 12 Posts
