Greetings,
So having been planning it for a while, the planets finally aligned in such a way as to actually allow me to perform the primary gear change I hear everyone raving about--commonly referred to as "3.37 gearing."
At any rate, last night I removed the stock 25-tooth compensating sprocket and 36-tooth clutch basket, and installed 24-tooth and 37-tooth replacements. The result? The primary gear reduction has been changed from 1.44:1 to 1.54:1 (3.37:1 final drive ratio as compared to 3.15:1, stock).
Wow. The perfomance of the bike has really changed. I don't notice any objectionable RPM increase--not even on the highway--but the torque multiplication from the increased mechanical advantage is VERY noticeable. Acceleration is "hell yeah!" fast, and the bike feels more like it effortlessly responds to right-hand input than before. Indeed, this feels like it is the "correct" gearing for the bike--whereas the stock gearing felt a little tall.
The debate over whether an overdrive 6-speed is called for will doubtlessly continue. But it is not "needed" as a result of the primary gearing swap, IMHO.
Thanks to Doc, MegaGlide and others for their advice. This is a kick-ass mod.
-Fat
-Fat
