1 - 11 of 11 Posts
I changed my primary oil over the weekend and noticed that the dealer had put a little of some sort of sealant on the primary drain plug. I have some Form-a-Gasket pliable sealant. Would this be OK to use?
Bob
Shithead
Depending on the model there's little to no pressure in there, or even vacuum.
I can't see why you would need any kind of sealant on the drain plug.
my .02; HD still uses pipe thread on this plug. pipe threads will let liquid flow in the root of the thread and it will eventually seap out. i use teflon tape. start it about two threads back from the starter thread. be careful when tightening up this plug. HD gives a distance measurement, not a torque value. if you tighten too much, the plug will act like a wedge and put stress on the primary cover and engine housing.
I posted a question a few months ago about stripping the threads out on the plug.......I did and many others have also.....Everyone says no big deal and so far the taflon tape works with no leaks, however the plug doesn't tighten up!
I use a locktite with teflon, one that does not dry. Not the same # as recommended. Like dope. Never leaks. One thing I have learned is that it is not good to let these bolts sit to long.
Manual recommends a type of locktite with teflon. Pretty sure mine has torque value too. Don't remember anything about depth.
The manual does give a torque value, read carefully, gives it in inch lbs. nor foot lbs! As I said before, many others have made the same mistake. If it does happen, the plug simply never draws tight.
I use Loctite thread sealant (white) and it seems to work fine.
1 - 11 of 11 Posts
