· Registered
i have adjusted the primary all the way out . just wandering if i replace the shoe will this give me anymore adjustment?
the sprokets look good (no sharp teeth). can i just replace chain or is it best to replace whole thing.
thanks for any reply.
its on a 1994 flhtc
· Registered
Got to look at the shoe, but if anything it will just give you a little more, it's not a long term solution.
Ideally you would replace the set, but the expensive part is the clutch basket, the chain and compensator sprocket are relatively cheap. Depends on circumstances.
· Registered
Replace the hole thing
