And they call it progress!!!!!!!!! Might be better off to compare costs of new HD cases + Zippers upgrade VS cases from the aftermarket that are already setup for timken tapered bearings on crankshaft.
That'll work for the 'A' engine, AFAIK there's currently nobody making Timken style cases for the 'B' model.Ed Y said:And they call it progress!!!!!!!!! Might be better off to compare costs of new HD cases + Zippers upgrade VS cases from the aftermarket that are already setup for timken tapered bearings on crankshaft.
Crank bearing failure fubared my motor, the Indy shop I know very well has seen several tensioner failures and the latest and greatest a cam bearing failure of a 2005 that took out the entire bottom end. Except the cases of cause. Don't know what your defintion of catastrophic failure is, but a complete rebuild of the lower end caused by sloppy design fits mine just fine.csoday said:I guess I'll worry about that after the "catastrophic failure" of the cases. Unless of course I tear it down after the "catastrophic" cam chain failure.
Yes, alive and kicking, only a couple miles on it yet. Will take it to the dyno for break in some time in February. Build was uneventfull, minor problems with fitment of cylinders on the case dowels and spiro locks that we did not expect.JDK20723 said:Vienna,
Is it back together yet? JK
