1 - 2 of 2 Posts
Can someone explain the lights and buttons on the PC USBIII, I have a canned map loaded for my 05. When Idling, the light shows all the way negative, when I rev it it goes towrds zero, but not into +, keep in mid I'm only reving to 2500 rpm. Is this correct? Also, what do the buttons do? The bike runs fine, just want to be sure this is correct.
Taken from FAQ section of Power Commander web site.
Q: On my Power Commander, the light is always at the lean mark during idle. Does this mean my bike is running too lean? It seems to get richer when I twist the throttle.
A: The lights on the Power Commander only indicate the throttle position when in “normal mode”. This is why they move up when you twist the throttle (they will not go all the way to the top of the display however).
In “button adjustment” mode the lights only indicate which direction you are moving the fuel curve, richer or leaner, than the base map.
Check out the Power Commander web site for user manuals and tutorials.
1 - 2 of 2 Posts
