Just for clarity, the ratio Donnie is talking about is the ratio of rod length to stroke.When all else fails read a book! This applies to me as well as sometimes we get too dependant on internet information. Donny Petersen's book "Volume 2: Performancing the Twin Cam" is a darn interesting read and for a while there was my "Bible" that I read every night. I dug it out from the book case to see what it says on the subject. I did find this paragraph that was interesting regarding connecting rod ratios that might be pertinent:
"Shorter con rod engines have opposite characteristics. They apply more force to the crank pin as crank-to-rod angularity increases above 20* after bottom-dead-center. Short con-rod-ratio engines will develop more TQ at lower engine speeds with an earlier end to the power band in terms of higher rpms. Lower con-rod ratios of say, 1.45:1 produce torquey engines with low rpm power bands that will run out of breath as higher rpms approach. Piston wear will also increase. The TC96 has a shorter con rod ratio than the TC88."
Mr. Petersen also states that a longer stroke will make more TQ early however as piston speeds increase it does make more vibration.
I'm sure this only helps to confuse the issue. Sorry!
-Tutt
Yup, that makes total sense to me! -TuttBeing a bit wiser these days, we like closer to square or over square configurations.
