after getting my bike back from a 103 build, i decided to take my k&n a/c off and glue in the velocity stack that kept falling out. first thing i noticed was several washers i dont remember being there, the backing plate calls for one washer on either side of the breather tubes. well i put it back together and see something has to be crooked cause the front breather needs several washers behind the backing plate. can something cause the intake or throttle body to be mis aligned?
They should have lined up the throttle body with the air cleaner backplate before tightening the throttle body. If you had a lot shaved off of your heads it could cause some alignment problems.
thanks for the reply. no shaving was done. i guess i should get my manual out. its not the first time ive had to follow up after someone else's work.
