I would like to ask for help. I have (moderate?) popping on decelleration, on my '02 FLHTCI, which occurs from about 3,000 R's to about 2,000 R's. Outside of that RPM range, things seems to be OK.
It has a H-D stage-1 reflash ECM, a SE A/C, and Khrome Werks HP-Plus 100 slip-ons. I have also installed a PCIIIr, with a map closest to my application (from their website).
The Powercommander website only has a map for the HP-Plus slip-ons, and not the HP-Plus 100's. So I am using the closest map available.
Is popping on decel caused from a too rich condition? As opposed to popping on accel, which is from a too lean condition?
Can I just lean out (make negative) the fuel values on the PC table, 0%throttle 2-3K RPM's?
I had tried a different PC map with a (-20) on all RPM's above 1,500 at 0% throttle, and it still popped on decel.
Any advice appreciated....THANKS!
Mitch
Mitch
