Here is my setup:
2006 Street Glide
KhromeWerks Touring Mufflers
SE Air Cleaner Kit
Power Commander
I have a map that I downloaded from the Power Commander website which is pretty close (was for 2002-2005 Touring). I was getting some decel popping at zero throttle between 4k – 2k RPMs. I fixed this by adding 10% fuel at zero throttle over this RPM range. Is this the right approach to take?
I have a slight problem of occasional popping back through the throttle body when the bike is at idle and I slightly blip the throttle. The bike then seems like it is going to stall, but doesn’t. This does not happen every time, rather once in a while. What do I need to change in the map to fix this problem?
2006 Street Glide
SE Air Cleaner Kit
Power Commander
