You guys can make up your own mind......me, well thought they would put in a bit more effort, maybe, politically they can not........hmm.
Hello,
I need your help, recently I purchased a front Monaco Design Front Wheel
in 21 x 2.15 plus 13" disc and 6 pot caliper and this was no problem.
I have just ordered the Left side brake kit (caliper and bracket), and
left side rotor and the 70T Pulley and 18 x 4.25 wheel and nothing fits!!
I believe somewhere in the mix up I was sent a standard rear wheel and
not a left side brake rear wheel.
So to get out of this fix I believe I need the right side rotor and brake
caliper and associated spacers and I should at least be ok with this.........so can you confirm this??
I also did not receive any response to an earlier email requesting information
about the brake line size to use with the drive side brake.
I ordered your products in the belief that they were the best........................and I don't know if you realize just how disappointed I am with this mess and I don't know who made the mistake in the order.................but it will cost me another 1000 dollars to fix someone else mistake.
Support[SMTP:[email protected]]
Sent: Monday, October 31, 2005 7:30:37 PM
To: Ozzie
Subject: RE: Monaco Order Through Wally`s Cycle World
My suggestion is to contact the dealer you purchased it through. A
driveside setup requires a different hub, and rotor. I do not know what else I can do to help.
Sent: Monday, October 31, 2005 6:05 AM
To: Tech Support
Subject: Monaco Order Through Wally`s Cycle World
Hey Ace, I have asked you a simple question, I just want to know if I
keep the 4 pot calliper from the left side brake kit and buy a right side disc and bra ket will this work??
Quoting Tech Support <[email protected]>:
No problem Ace. No, the driveside four piston caliper will not work on a
standard brake system. You will have to replace the entire caliper and
bracket with the appropriate one.
Sent: Tuesday, November 1, 2005
To: Tech Support
Gee Frank, thank you so much for your response, I was looking for help as I just purchased approx 6000 worth of PM Parts and if that is the best you can do for me........I will never buy PM anything again!
I am sorry I bought any of your products in the first place......I expected better than that.
Guess my order like that of many is too insignificant for you big guns in the motorcycle industry.
Tell you what I will do Frank....I will put all of this up on the VTwin forum for my brothers to see and then they can make up their minds about you. Ace!
Ozzie
Hello,
To: Ozzie
To: Tech Support
To: Tech Support
Ozzie
