Any opinions? Lean, normal?
Looks like mine when I used to run octane booster.. That stuff really turns them rusty looking.. I don't use it anymoreAny opinions? Lean, normal? View attachment 273137
First suggestion... Know exactly what Pre-ignition sounds like. 2nd, I like yer Fuel Choice. 3rd, I;m thinking that with a Large Bleed, you are bringing the main in too late, Popping Lean??Originally before I replaced the cam etc. I was trying to stop a noise I was hearing and many suggested higher octane, so I was adding Lucas octane booster for a couple tanks worth of fuel. Now I am running ethanol free 90+ octane. Headed to pick up my new plugs. I'll run it and see what they look like. I feel like maybe a 66 air bleed is to big? It came with a 40 installed. 2k-3 1/2k rpm is where I get the issue.
There are still a couple of places around here that have pumps of VP110. Leaded. The last time I looked it was $8.50 a gal. Before this current economic fiasco. Years ago, you could pump it straight into your tank. Now only into a gas can. I ran it 50/50 in my EVO FX. Not a "true high performance" engine, but enough that I did have some detonation..... Quality Race Gas seems to still have real Gasoline with various additives, including Lead, (in some) the stuff I like to mix with gas in "true high performance" engines....
But... Cheaper than the result of Pre-ignition!!!There are still a couple of places around here that have pumps of VP110. Leaded. The last time I looked it was $8.50 a gal. Before this current economic fiasco. Years ago, you could pump it straight into your tank. Now only into a gas can. I ran it 50/50 in my EVO FX. Not a "true high performance" engine, but enough that I did have some detonation.
Now, nothing but ethanol free premium, 90 or 93. 50¢ or more extra per gallon and an 8-10 mile drive to get to the stations that sell it. Worth it to me. But getting harder to justify in my pea brain.
