Please Help on Wiring
Wire up the driving lights and connecting to yellow wire in headlight housing. There are 2 yellow wires that go to bulb. Does it matter which one?
One is high beam one is low beam. A volt meter will tell you which one to use. Some states have some laws where you cannot have driving lights on and high beam?? The driving lights wired into the head light may cause a issue if you draw too much power though the stock wire. The result may be a melted harness. I like to run power wires that are larger to ensure that does not happen. Now if it is a HD kit and you are using stock head lamp bulb you should be ok.
