1 - 13 of 13 Posts
member
Hey Y'all !
Well I am almost ashamed to ask this question, but once asked I won't have to ask again! I just bought my '01 deuce and I didn't get a manaul with it. I will buy one. I am trying to change the oil. It looks like a small plug in the bottom of the crankcase is the drain? It has a small 1/4" allen head plug in it. Is this the drain point? If so wow it is tight, I have tried to remove it with a small allen wrench, but Iis going to require a cheater bar on it for help. Bfore I do this I want to be sure am doing the right thing. An once of prevention is worth a pound of cure as they say! Is there some sort of locktite on the plug? I know ther isn't a drain onthe oil tank. Sorry to ask such a simple question, but if i knew I wouldn't have to ask! Thanks y'all-Rob:) :)
Three plugs.
1 Dummy
1 Trans
and 1 Engine.
The one you are messing with, verticle or horizontal?
member
Vertical, on the bottom of the crankcase
Sounds like your Tranny to me, but wait and let the JimmyK or somebody confirm.
(I've a RoadKing, they might be different?)
Yep that is the trans OR the dummy bolt. Probably the dummy bolt.
Look for teh Horizontal plig front left of pan.
THE horizontal PLIG :D
To be honest, the best advice I could give, in that I don't know where exactly you are talking about is wait and get the manual. Do the channge next weekend.
Free Idears Available
the softails oil drain is actually in the swingarm. right side near the front of the swingarm up in a recessed area. allen plug.
the trans is up between the shocks
the primary is, well.... under the primary
There's a frame support that runs between the left and right frame tubes, just to the rear of the shocks. On the right side of that you'll see a 5/8" plug. That's what you're looking for. You'll see a hose running from that plug to the oil tank in case you want to verify.
-jeff
member
Discussion Starter #11
Thanks y'all! I did find it! Logical you are right on the $$. thanks for steering me in the right direction. That dummy plug still has me baffled. But hey, I didn't get it out! I may still wait on the manual, just to know the exact procedure and amount of oil. But every manual I have had has always come up a little short of the full mark with thei oil recomendations.
Thanks to all who replied I appreciate it!-Rob
Hey Rob , sorry man I was talking touring model. It is best to wait on the manual. It will take you through step by step and they are quite good.
member
Discussion Starter #13
Jimmy, No problem! Thanks for trying. I am going to wait on the manual. Just goes to show all Harleys ain't as alike as most people think! Thanks again-Rob
1 - 13 of 13 Posts
