when i torque my cone nut (right side) to 95-105 foot pounds my right cam plate,adjuster,1/2 moon plate or whatever you call it rotates away (looser) from the boss on the swing arm. it is supposed to be in contact even when torqued down. i have tried putting antisieze between the back side of the nut and on the face side of the cam adjuster. still it moves. then i used vicegrips to pinch the adjuster to the swing arm. still it moved. then vicegrips on again and blocked it between the ground and the bottom of the pliers.that worked but a real pain in the a**. i am hoping someone else has a better solution.
thanks
thanks
