Does anyone know if the pinstrips on Fatboys are hand-painted or a decal? If they're hand painted, is there anyone out there making a Harley specific templete for them so I don't have to try to do them free hand or with striping tape?
Thanks,
Steven
stripes
they're "hand painted" in the sense that they're done with human hands, as opposed to how a pinstriper may do it with a brush. These are done with a template ( a custom made piece that lays on each side of tank to guide striping tool around) and a striping tool-not a brush. From what i understand like a Beugler or a Passche flow pencil. Make a pattern off the other side and flip it over and transfer layout. Any competent pinstriper should be able to do this.
Is it a 2 color stripe/2 stripe design? Single color / double pinline?
No. it's not a decal. I seriously doubt that theres a template for sale either, although maybe it's on the net somewhere. Re-doing both sides (a complete) or just a repair? Sorry i can't be of more help. Tim
i have watched them paint the pin stripes on tanks at the tomahawk plant and they are done with a template.
Thanks for the help. I have the tools to do it, just been a while since I've laid some down and after talking with the dealership, it's hard to get those colors in the pinstripe. I have the maroon and silver pinstripes on a pearl white bike. I'm in this situation cause I'm switching to a deluxe rear fender so I can run a set of road king hard bags with the bagger tail setup.
The guy at the dealership suggested just taking it to a ppg shop and have them shoot it with the color gun but I want it all to really match.
Anyone know where I might could get that templete???
Thanks,
Steven
striping template
Don't count on that happening. The "template" is more like a fixture... a tank half sized piece that is set up for right & left sides that the pinstripe tool rides up against. For the fender HD probably has something similar. Just measure what you have now or use a deluxe to measure off of...shoot the pearl white, clear it, scuff/sand the clear, measure, layout (then double check measurements) stripe color one, let dry, stripe color two, then bury in clear....color sand & polish....done.
oh yeah...i indicated an extra clear BEFORE striping...that way any mistakes can still me wiped off & not ruin the pearl white base. Unless you do this all the time, trust me , it will work out better with this extra step.
Good luck.
Easy way to do it would be to tape it out using 1/8" blue fineline (same tape used to draw out flames), then masking it off. You could either paint it on with an airbrush, or try using a mack striping brush. Because you would have masked it, you will get crisp edges on your lines and it will look professionally done.
I have done that in a few 2tone paint job applications, airbrushed the stripe on, and it came out great. I have pics on my website - one was a fat boy, the other was a heritage, oh and I also did a sporty tank in a kustom factory scheme...
Good luck!
