1 - 8 of 8 Posts
Looking for recommendations for a pinch clamp tool and if any specific clamps are recommended.
Are you referring to the clamps on the oil lines? I replaced mine with fuel injection clamps when needed.
Oetiker if you really want to go that route.
Buy your hose before you order the clamps.
Personally, I like these a lot more.
https://www.amazon.com/Fuel-Injection-Hose-Clamps-Pack/dp/B0040CU0JA
I use both and these are better if you think you might ned to take them off sometime.
Assuming you are talking about this style clamp:
https://www.summitracing.com/parts/sum-390511
I bought this tool and it works very well:
https://www.summitracing.com/parts/sum-900155
These are the Oetiker clamps and they're great. The tools are also available on Amazon with either a front or front and side jaw.
Both types work well but the Oetikers can be SOBs to remove until you learnt the "trick" and then you need to tool to put new ones on.
1 - 8 of 8 Posts
