1 - 20 of 27 Posts
Just got done putting this thing on, i had a question the 2 breather hoses on the engine that go into the back of the stock intake, as u can see in the pics i just cut them down and capped them with mini-airfilter, which works fine but i was wondering if there was someone who made a part that maybe has a metal tube that comes out of it made for this type of application so they dont move around in the wind, i wanna make it as efficient as possible, thanks.
the tubing does block the wind, the front one has support because when it gets hit with the wind it just pushes against the tube anyway, i took it on a test drive around the block and watched it, they didnt move much, but im thinking about a long trip i dont want any problems, plus i think if someone made breather hole screws with metal tubing attached it would look better too than the rubber hoses
Here for the education!
you need to have a bracket that mounts to the throttle body and the two breather holes in each head. If you dont you WILL have intake seals issues not to mention a good chance that baby will be hanging from the throttle cables after about 20 miles! The stock backing plate acted as this bracket from the factory, not sure whats is available aftermarket yet for these.
Discussion Starter #8
well, what should i do? my intake doesnt go up to the breather holes, i know what youre talking about though my buddy has a intake that goes up to the holes, it wont work the way i have it?
Discussion Starter #11
it wont let me view the pic because i dont have the upgraded membership, there a link u can put in?
but jeez i understand what you guys are talking about now, man i feel dumb ya those holes were supporting the throttle body, i understand now
Premium octane member
CRAZY_TRAIN said:
nevermind i paid the 15 bucks heh, ya i need to get one of those, are they available for my bike? and also, those holes can be plugged? they dont need air flow?
NO!!! the breather holes can not be blocked. If you do it will build some serious pressure inside the motor. Your dipstick might pop out and gaskets start leaking.
Discussion Starter #18
thanks man, i love it, i was kinda bummed because i thought at first you guys were telling me i couldnt use it, i just need to get that support bracket, but the bolts that hold it in, are they hollow or something? how do they allow it to breath?
Discussion Starter #20
i got some kind of bracket, but it doesnt have the elbows that go up to bolt into the holes, its like a universal adapter that goes on the throttle before the intake incase your holes are different
1 - 20 of 27 Posts
