I own a 2001 Night Train. It is currently running a Pro Pipe HS, K&N S/E filter with a Dynojet in kit the stock CV. Stock everything else.
I ride one-up, 180lb. rider, Mid-Atlantic states, year round (dry weather primarily), mix between stop and go traffic of metro D.C. and Blue Ridge mountain runs.
Don't care about top end HP or WOT bursts. Love torque, low end, and useable cruising power. I love the enhancement to the power band the V&H PP did for me replacing 2 1/4" drag pipes and would like more of it.
The eventuality will be a 95" hop up of some flavor.
I *think* I like the power band numbers the TW37 yields.
The question is if I can do this in phases.
Can I do the gear-drive upgrade with 37G camset along with a Baisley thereby covering the bottom end and doing the heads and cylinders later?
I know common wisdom is to do it all at once but that is not in the cards for me at this time. I want to dump that cam chain tensioner bugger and thought I could do the switch to gear drive now with better cams.
Will the 37G be "OK" (if not ideal) until big bore time?
I don't want to get interim cams only to swap them out later.
If the 37 is a dog with an otherwise stock motor I have to figure out something else or not do anything at all for now.
Thanks,
Bret
Thanks,
Bret
